Featured Photos
by Mick
Mick's '00 RC
7 photos
0 comments
by Stel67
Member Galleries
2098 photos
646 comments
by wolf44
Member Galleries
2098 photos
646 comments
by C. Dolan
Bike Pics
83 photos
44 comments
Old 07-19-2008, 04:06 AM
900SS/FE 900SS/FE is offline
Default Can the Paul Smart go Bi?
Biposto that is?
Can you take the parts from the newer Sports and make the Paul Smart a two seater, or is there different framework I need to be aware of?
Thanks in advance for the help!
Cliff
Old 07-22-2008, 02:36 AM
mooner mooner is offline
Yes, it been done. Go over to Ducati.ms and do a search.
Old 07-24-2008, 04:47 PM
Thanks for the response. I found that shortly after posting here.
Old 07-25-2008, 03:10 AM
motoxxx79 motoxxx79 is offline
i made my sport a bip setup..... i fabed up some mounts and used rear foot pegs from an 800ss...i have yet to ride anyone yet tho.... i'll try to post some pics this weekend
Old 07-25-2008, 08:08 AM
Thanks Moto, it would be cool to see another person's solution. The others I've seen didn't quite work for me asthetically.
Old 07-26-2008, 04:27 PM
ok, heres what i did..... I removed the stock bolts going through the top of the shock and supporting the exhasut and replaced them with some stainless hardware from ACE (grade 8, and a Flat head...) I then drilled and tapped into them so they would accept an M6x25 bolt. I then used some clamps that i had to clamp to the frame and ran a longer bolt from the rear mounting hole of the passanger rearset through the clamp, using a piece of pipe as a spacer. I used stainless hardware (but not pipe...doh!) and made sure to use Nyloc nuts so nothing would rattle loose. So far, i have about 2k miles, and no problem on this setup and i DON'T take it easy on my bike! Let me know what you think.
Old 09-12-2008, 07:10 AM
Definately the best solution I've seen someone put together so far. Thanks for taking the time to post these up!
