I got mine done yesterday at Del Amo Motorsports in L.A. Here's what they did:
3.5 qts Motul oil, 1 oil filter, 1 gasket, 1 washer, 1 brake cleaner, 1 chain clean, 1 chain lube. Parts subtotal: $53.35. Labor included: clean air filter, check spark plugs, check/adjust cam belt tension, replace oil/filter, top off all fluids, clean/lube/adjust chain, torque all critical fasteners, check tire pressure, adjust/lube cables, inspect bearings, inspect electrical fittings/connectors.
Labor subtotal: $315.
Tom
