That caught your interest
I have been fiddling with my PC111 to get the bike running as good as I can prior to taking it to the big city for a dyno run in a coupla months.
I have left it as a zero map as the MH OEM map seems to be good so the basis of fueling it up is only for mixture correction.
I set the cyl trim to plus 5% for both cylinders and after a coupla road tests I established it was still not quite there, I set to and manually adjusted the fine tune scale a further two points up and now it runs as strong as an ox, no coughs or splutters.
Idling was way too rich at that and it sputtered on startup and felt gooey, both air bleeds were set at 1.75 turns from the base setting, again after resetting these both even at 4 turns out from the base the bike cracks into life with no throttle and idles beautifully.
So for the moment it is fueled up approx 5.2% from factory, this seems to work well with the pods and stacks and the full length balanced headers.
We will be taking it to a dyno and I will post the results once done, it would think there might another 2-3 HP from opening it up and fueling it correctly, time will tell.
The seat dyno says it has another 100 HP 8-D
