Go Back   Speedzilla Motorcycle Message Forums > Ducati Message Boards > Ducati Hypermotard
Old 06-26-2009, 06:10 PM
AzBill's Avatar
AzBill AzBill is offline
Chrome Member
Smile Turbocharged HyperMotard Project
I'm moving forward with turbocharging my HyperMotard. I'll be using an Aerocharger 53 Series Turbo and RapidBike Electronics.
My plan was for the turbo bracket/intake pipes to be a direct replacement for the CAT only. Unfortunitly it wasn't possible. It was about 3/4" off. So the lower horizontal head pipe will need to be modified.
I'll be using the stock mid pipe with the flapper valve removed. I'll also be using the stock slip-ons (cored to reduce back pressure).
More info/pix:
DucCutters: HyperKromo: Phase 2 (Bill Johnson)
Bill Johnson (Arizona)
'69 Ducati Moose350 • '96 Ducati TurboMonster • '08 Ducati HyperKromo
Old 07-01-2009, 02:37 AM
viper1 viper1 is offline
That is F'ing crazy!
Old 07-05-2009, 01:35 PM
GAMBLER's Avatar
GAMBLER GAMBLER is offline
contra mundum
very kewl
please keep us updated with progress
Old 07-06-2009, 09:49 PM
AzBill's Avatar
Chrome Member
Smile Update: 07/06/09
I finalized the design of the new air-box and sent the drawing s out to be water-jet cut. I have a set of velocity stacks on order and well as a few other items I need to complete this part of the project.
I hope to get the electronics order this week...
More Info:
Shift-Tech's HyperMotard Bayliss Edition has 130Hp ($9.4K in engine work), so my goal now is to make at least 131Hp.
Old 07-22-2009, 01:42 AM
couchflyer couchflyer is offline
Zombies, I have a plan
Nice work
Life is too short not to be Italian
Old 08-06-2009, 10:41 PM
AzBill's Avatar
Chrome Member
Smile Update: 08/06/09
All the hardware is complete now. The mockup turbo has been shipped back. The real aerocharge should be here soon. The electronics are also "in the mail"...
The exhaust and the air box will both be ceramic coated black once I get the electronics installed and hook up the MAP sensor.
Hoping to be done by the end of the month...
Old 08-13-2009, 02:39 PM
toxic toxic is offline
I'm very excited to see how this turns out!
Old 09-24-2009, 02:21 PM
Multitard Multitard is offline
What kind of EMS will you be running? I'm interested to see it come together as well.
2000 795cc Supersport
Old 09-24-2009, 04:58 PM
AzBill's Avatar
Chrome Member
Smile RapidBike...
Project almost done. There's been a few delays...
I currently setting up the RapidBike Mod 3 system with an integrated MAP sensor. The "RapidBike 3" allows for the adjustment of fuel and timing, which will be based on the manifold pressure.
More info/pix:
Old 09-29-2009, 08:31 PM
AzBill's Avatar
Chrome Member
Smile Update: 02/29/09
Mechanical work complete! The bike is all back together and I delivered it to "Tom's Italian Tune & Service" for helping tuning it.
The RapidBike system seam to be a little problematic. Hopefully we can figure it out soon...
Old 10-26-2009, 11:35 PM
Mr.Duc's Avatar
Mr.Duc Mr.Duc is offline
Duc-again
Why Turbo a Hyper? Even if you gain 10 Hp what will that do? Are you drag racing it? Is it too slow for you? Some pistons, cams, and tuning can get you to 110-120 hp. I would never have the balls to cut up a new bike like that. Good luck and be careful.........
998 Yellow.......the money pit! Lumpy cams, naughty pistons and fat pipes
998 red mono----RIP
Looking for a 2000 or newer 900 monster
2002 CR250R aka dirty mistress
Old 11-18-2009, 03:52 PM
Originally Posted by Mr.Duc View Post
Why Turbo a Hyper?
Because he can.
Any updates???
Old 11-18-2009, 05:36 PM
AzBill's Avatar
Chrome Member
Smile Update: Nov 18, 2009
After over coming the Rapid Bike issues, I took the first "Turbocharged HyperMotard (aka HyperKromo)" for it's first test ride. Everything went well. After a few test rides, we'll take it to the Dyno for final tuning (hopefully next week).
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
