Hypermotard HP Numbers - Speedzilla Motorcycle Message Forums
Go Back   Speedzilla Motorcycle Message Forums > Ducati Message Boards > Ducati Hypermotard
Old 10-03-2008, 06:17 PM
Dis Member
Default Hypermotard HP Numbers
Here are some numbers from our dyno.
A couple things I should mention is that these are not from the same bike nor are all the runs from the same day/conditions but the graph gives you a good idea of the gains from the DP parts.
Also, our dyno seems to register about 5% lower than most Dynojet 250i dynos.
Ducati Indianapolis : Articles
IndyDucati
Old 10-07-2008, 01:20 AM
It was always said you lose about 10% from the crank to the rear wheel, which would be about right considering Ducatis claims 90 (stock) at the crank!
