dave(the owner of this site)is a carozzeria dealer
the main guy at carozzeria used to be my friends mechanic when he was a pro racer here in japan
the wheels used to be called hi point
I need sprocket carrier bolts for a set of hi points. I'm sure the design should all be the same but the bolts actually also fit into the cush drive in the back. I can use a full set but only REALLY need two. Do you have any or can you get me some?
Can you post a pic? I might have some or at least be able to get them for you.
